Intermittant brake warning message
thomb
The low brake fluid warning message appears intermittantly on my 2002 RR.
Every time I check, the fluid level is actually just above the Max line. I have no stopping problems or odd noises.
Truck has about 98K - I've put on 40K of that and have not changed the brake pads so they may be reaching end of life, but I'm not seeing how that would relate to the low fuild warning light :confused:
Might need to flush the brake system... could be dirty fluid... remember you should change brake fluid every 2 years.
Paul p
