Intermittent electrical problems when starting my 98 Disco
baysiderover
On several occasions after starting the car I noticed that the radio, windows and electric side view mirrors will not work (there may be more not working but that’s all I noticed). If I shut off the car and start it again everything returns to normal – every time.
Has anyone else experienced this? Any ideas of what could be causing this?
Thanks
I would start with a corrosion/connector check. Under the steering column connections, and fuse blocks for corrosion/connector connectivity.
More than likely a connector under the steering wheel is not connecting cleanly.
Could also be a sign of battery/alternator issues.
baysiderover
I recently installed a new battery and everything checkout (according to Sears). I will check the connectors this weekend. Thanks
tommy33
Again, I followed Joey's suggestion and cleaned the fuse block that is under the hood behind the battery. My intermittant electrical problems stopped.
97 Disco 91k miles.
MArsel
