Leaking water??
Steve T
Annapolis MD
hey folks, I have a 2011 LR4 LUX and it started leaking water every time it rains. The leak seems to be from either water pooling up under the sunroof and finding its way through the AirBag plastic covers on the A pillars and through the overhead map/Done light.. Anyone else have this issue before?
Any easy fixes... I know that’s kind of silly, nothing seems easy on these rigs :D
Sunroof drains are probably clogged. I am sure someone on here has posted a way to fix this.
scott schmerge
Charlotte, NC
hey folks, I have a 2011 LR4 LUX and it started leaking water every time it rains. The leak seems to be from either water pooling up under the sunroof and finding its way through the AirBag plastic covers on the A pillars and through the overhead map/Done light.. Anyone else have this issue before?Any easy fixes... I know that’s kind of silly, nothing seems easy on these rigs :D
Easy fix. Sunroof drains clogged. Use a spool of **** eater line. YouTube it. Fixed mine in 5 minutes. Alternatively if you have a compressor you can use air to unclog it. I have not tried this method.
