Look of LR4 2009+ for LR3 2008
PhilSessions
I like the exterior look of the LR3 in its entirety. I wouldn't change a single bit....as for the interior, the LR4 is way nicer and I'm jealous of the extra horsepower.
I couldn't agree with you more! i absolutely love the looks of my LR3, but the 4 not so much. Its like they went Lexus on us or something. Mine is in the shop tonight and they loaned me a LR4 and man the horsepower is bloody awesome! The interior makes me want to take my shoes off as with the LR3 I don't mind my muddy Redwings all over the place. Would love to drop that engine in mine. Wooohooooo!
Sonies
Sonies, what's the evidence that they're going to have to carbon clean their forced injection engine every 10k miles or so? What are the symptoms of the problem and what does it cost?
Here, read this, again, not sure if this is a problem on newer models, I certainly hope not.
symptoms are that there is motor oil being ingested into the PCV system, and frying itself on the hot intake valves (and leaking into the combustion chamber). On port fuel injection engines the fuel washes much of it away, but with direct injection the intake path is dry, or at least it's supposed to be. Oil in the PCV system is the bane of DFI cars, and some of the first generation designs did not include effective oil separators.
DFI
Direct Fuel Injection (DFI), is a new technology that Porsche states can cut fuel consumption by up to 15 percent, while increasing power by up to 13 percent. DFI cuts emissions by warming up the catalytic converter more quickly, and ensures a sharper throttle response. Better for your right foot - and the planet, then.
DFI allows much more precise measurement of fuel supply and injection at pressures up to 120 bar; it has numerous combustion modes, with different cycles for cold-starting, low-speed driving and performance driving.
As the name suggests, DFI injects fuel directly into the individual combustion chambers, instead of the intake manifold. The injector valves have an electromagnetic mechanism that controls each injection with astonishing precision, while a high-pressure pump provides the necessary pressure—up to 1,740 psi—to accompany the rapid fire of the fuel injection.
Precise geometry of the injector’s position and its spray pattern is a key factor in helping to improve power, torque and emissions of the engines. The specific placement of the fuel as it enters each chamber creates a swirl that improves the air/fuel mixture, and therefore the overall combustion process.
At engine speeds up to 3500 rpm, a double-injection process is used. In this mode, the required fuel volume is delivered in two successive injections per working ******. The resulting benefits include faster catalyst warm-up and increased torque in the upper load range.
By forming the air/fuel mix directly in the combustion chamber, DFI contributes to engine cooling. As a result, it is possible to increase the compression ratio and with it the power and efficiency of the engine.
The direct injection process is continuously adjusted. The engine management system reads changes to throttle inputs and performance requirements and, as you drive, the air/fuel mix is monitored and adapted as required. Oxygen sensor circuits within the exhaust system provide accurate emissions control.
Sonies
I am sure when the time comes , this will be duable in Lr3 , with a right mind and computer reprograming...
can't you just slap a supercharger on it and get the same effect?
taylorover
I'm not sure if you can put a supercharger on an LR3 engine. The Range Rover Sport is basically the same vehicle and they start with the same 4.2 liter Jag engine. The standard RRS engine and LR3 engine are bored out to 4.4 liters, but they supercharge the 4.2 liter in the RRS citing something about leaving the walls of the head thicker to deal with the increased pressure. I wondered what would be involved in dropping a supercharged 4.2 liter engine in my LR3.
