LR3 shift up down switch
Bigtaku
Has anyone had an error code with the up down switch on the transmission? My 2006 LR3 just started to have trouble going from a stop to shifting in gear. The RPMs shoot up and then after a few seconds it decides to shift into gear. doesn't happen everytime though and it seems to be getting better.
Had a transmission fault on the dash show up so I took to my local shop to take a look at the code. He made a copy of the data and printed it out for me and it seemed to be all fixed when I left. No charge, great shop. The computer read; component data - P0826 Up and down shift switch circuit. No codes present.
He told me to drive it around a bit to see if it starts up again. It happening just enough to be worry about it. I was wondering if a small rock or something got stuck in my shift console. wishful thinking I think.
How many miles? I had a strange anomoly regarding shift points that has not come back after a fluid change, believe it or not.
tlt
Is the gearshift indicator matching.
There are issues particular in rust belts with some shift fork rusting up.
Auto Gearbox Lever How To
www. disco3. co. uk /forum/topic31656.html
LR012704 - Lever £2.96
WYH000040 - Nut - flanged £0.42
VYH500020 - Nut - Hex £0.42
TYG000050 - Bolt £2.02
TZT500040 - Bush £3.43
TYF000050 - Washer - spring £2.63
Others have reported wild revving and such issues related to the viscous fan clutch failing.
