Lr4 2013 vibrating speakers
cypress822
Any info that anyone is aware of regarding vibrating speakers when radio is on??
I am sorry, but I laughed out loud when I read this.
You are going to need to explain a bit more. Do you mean some trim is making noise that you wouldn't expect? Obviously the speakers are going to vibrate to make sound.
TXLR4
stupid question...but how high is the bass and subwoofer turned up? Maybe try turning it down to see if that helps?
rovernut
I chose to keep my thoughts to myself, but you're right on track! ummm the speakers produce sound by vibrating....
I'm guessing there is some loose trim somewhere and there's rattle or buzz..OP?
If your base is not set real high then the speaker is failing and will need to be replaced.
