My First Post & a Help Request
ericdearie10
Hi,
This is my first post and a wee bit cheeky I know but I have a couple of problems with my UK Range Rover HSE TDV6 with 61000 miles:
1. As of today, the air conditioning isn't working. The switch still lights up when pressed but the is no change in the blow air temperature. Basically the temperature is the same whther the switch is pressed or not. I've checked the fuses and all is OK there. Any suggestions before i take it to my LR dealer?
2. When my car was in for its last service, the external temperature sensor indicator has been changed to fahrenheit. Any suggestions on how I get it back to centigrade again, or will this entail another visit to my LR dealer to remedy?
Thanks.
Eric.
Welcome to the forum.
A/C may be low on freon or R134a or whatever is used in the UK.
F to C = IIRC Press and hold the two outer of the air select buttons ie air to face, air to feet etc. to change celsius to farenheit, and vise versa
ericdearie10
First Post & Help Request
Hi Joey,
Thanks for the fast reply:
1. I'll get it checked out.
2. Tried your suggestion to change from F to C. No joy!
Eric.
