My New Lights
angasreid
Oh it's the whole shebang. Didn't realize it was the housing too. My bad.
c3c
Yep..I wish I could sell halogen bulbs for $300.00!
Hi,
Not sure, but I assume you changed the old halogen setup, and just plugged in the projection light (hid) with same connectors? I have the LR3 SE with the regular halogen and no fogs?
Thanks!
c3c
Yep, it is the same connector. Get the non-adaptive ones!
tomasesto
led lights?
Slight price drop...already listed on ebay...Item number 140382272741
http://cgi.ebay.com/ebaymotors/ws/e...=SI&itu=UCI&otn=18&po=LVI&ps=54#ht_500wt_1182
c3c didnt you replace all your interior and exterior marker signal running and brake lites with LED equivalents in a previous thread? Id like to replace all mine also since I finally found some OEM Zenons so now ready for the rest. Can you point me in the right direction cuz been outta the loop for awhile.. :confused:
tomasesto
led lights?
The adaptive will fit but not function correctly and bounce back an forth.
As I said above they will flicker some when first powered on. Weather left to right or some other way doesn't matter.
Since your vehicle was not orginally fitted with xenons the option is not turned on in the car computer so it powers up slower. You can get it turned on at a dealer or independent shop and it will flicker less.
Trynian,
Im trying to update the lighting on my interior and exterior with LEDs and wonder do you know wether this change may cause any electrical faults?
