new owner with problems
S
skmartin6
Just bought a 1996 discovery at an auction found a few problems when i got it home. The turn signals don't work but em.flushers do. The radio doesn't recognize the cd player & the cruise won't work button lights up but nothing happens need help. THANKS
T
tempestv8
I am surprised that you were able to buy a vehicle from the auctions which is not roadworthy. Are you able to take it back to them and get it sorted out? An auction should not be selling a vehicle that is not roadworthy.
Re the radio, sorry can't help.
Re the cruise control it's probably cracked vacuum hoses. Find the vacuum hose in the engine bay and cut off the cracked end and rejoin the hose. You'll most likely be able to get cruise to work again. This is a common problem and what I described there is a common fix.
Regards,
Lawrance
R
RoverDisco98
The radio will show "CD" in the channel display unless you actually have one or more CD loaded in the unit under the right side seat.
Also check the release switch located above the brake padal, if it's not seated properly against the pedal arm it willnot close the vacumn line
S
skmartin6
Thanks, actually the vehicle is in very good shape w/120,000 miles. Gave $4000 for it. I got it for my son who will turn 16 in january. Just have a few problems to work out. Thanks agian for the help Tim
S
skmartin6
As for the cd player you can load cd's put it in the player and it takes them out but when you go through the modes on the stereo it doesn't show cd on the display. Tim
S
skmartin6
AS for the turn signals all the bulbs are good. You can turn on the emergancy flashers and the lights work fine but nothing with the turn signal lever ? This one needs fixed.
Tim
Moose
Start simple: Check fuses, connections, things like that. It could be the switch as well...
S
skmartin6
Hey guys got the turn signals and cruise working. I'm not sure what I did on the turn signal "thats scary" but the cruise had both cracked hoses & the switch at the brake pedal had poped out of its mounting braket just enough that it wasn't making contact.Thanks for the help.Now who can help with the cd changer?
Thanks
Tim
Moose
RE: the signals -- welcome to The Cult of Lucas! :biggrin:
There are more weird things that happen with these British electrics than with any other make or model of car. Rover, Jaguar, Triumph, Aston-Martin, etc., all have crappy electrics.
philfeal
