Non-Bias Input
twoboarders
First off, I have been a member here for 3 years and can't thank all of you enough for the insight and education. That being said, I'm moving out of WA in April and don't intent on taking my LR3 with me. After hundreds of hours of research I'm leaning towards an asking price of $8,500. I see prices all over the place and would greatly appreciate any suggestions you think is a fair price. Obviously I'm bias.
Attached a few pictures so you get the gist of condition/look.
5 year repair history below. All completed at the Land Rover dealership.
01.26.18 Oil Change 137,007
08.31.17 Oil Change 132,437
01.14.17 Oil Change 124,945
07.16.16 Oil Change 109,316
11.23.15 Oil Change 109,316
09.03.15 Oil Change 105,067
03.06.15 Oil Change 97,364
10.03.14 Oil Change 89,929
03.03.14 Oil Change 82,562
08.01.13 Oil Change 75,188
Brakes
07.01.16 Front and Rear Brakes (Pads, Rotors, Sensors) 116,574
03.03.14 Rear & Parking Brakes (Pads, Rotors, Sensors) 82,951
10.09.12 Front Brakes Pads, Rotors, Sensors 65,010
Transmission, Transfer Case, Differentials
08.31.17 Front Differential Fluid 132,437
08.31.17 Rear Differential Fluid 132,437
11.30.16 Major Transmission Service 123,353
08.24.16 Transfer Case Fluid 119,550
11.23.15 Front Differential Fluid 109,316
09.03.15 Rear Differential Fluid 105,067
05.22.15 Transfer Case Control Module 101,274
08.01.13 Front Differential Fluid 75,188
08.01.13 Transfer Case Fluid 75,188
Repairs
01.18.18 Primary, Secondary Belts (2) Tension Pulleys (2) 136,121
01.11.18 Installed Lucky 8 Lift Rods 136,121
02.17.17 Cleaned ABS module pins and connector terminals 125,848
08.24.16 Mount and Balance 4 New BFG Tires 119,550
08.24.16 Replace PCV Valve 119,550
07.29.15 Front Height Sensors and Jumper Wires 103,474
06.19.15 Repinned wiring at ABS module 102,158
06.05.15 Wiper Cowling 101,925
05.22.15 Wiper Cowling 101,274
05.22.15 A Pillar Repair Kit 101,274
05.22.15 A Pillar Trim Clips 101,274
05.01.15 Chaffed wire on rear frame. Wiring Kit 100,747
03.28.15 Front Diff Vent n/a
02.27.15 All Terrain Switch 96,569
02.20.15 Brake Light Switch 96,464
02.16.15 Brake Light Switch 96,004
01.06.15 Alternator 93,370
10.03.14 Spark Plugs 89,929
10.03.14 Replace Both Lower Control Arm Bushings 89,929
10.03.14 Thermostat Housing, Antifreeze, Valve Air Bleed 89,929
06.14.14 Starter Motor 85,926
06.06.14 Battery 85,926
03.03.14 Adjust A Pillar Posts 82,562
12.31.12 Mount and Balance 4 New Tires with Alignment 67,662
11.07.12 Throttle Body Cleaning 65,694
11.07.12 Replace Mass Air Flow Sensor 65,694
10.26.12 Replace Thermostat 65,010
jwest
Seattle WA
Great list. Year? ;)
How many owners if you know?
Which dealer?
Parking sensors not there which is odd. Do you know the options list?
3rd Row?
Otherwise i see the nav which means it has most options - just odd not having the sensors although LR did weird things year to year on what's included vs stand alone.
What's the spare tire seeing as it looks like you maybe at least have some size bigger than stock?
Towing kit?
Most anyone would want to know this stuff so just trying to help ;)
twoboarders
Thanks, forgot some obvious....
  • 2005 SE
  • Dealer = Landrover of Tacoma
  • 2 owner I believe. Above dealer took delivery new. I have LR3 full service log printout from service advisor showing work completed prior to my ownership
  • No parking sensors. Have HID and Nav. Not adaptive
  • No 3rd row
  • Tires are BFG 265 KO2. Installed by dealer and had zero rub issues prior to rod. Lift rods are Lucky’s that I just put on in Dec
  • I’ve never attached a hitch or towed any thing
Hope that helps. Price input?
...so tempting to get a 2nd LR3!!!
twoboarders
According to Landrover dealer on Jan 26th 2018 BFG’s are at 13/32nds and brakes are 7 mm.
Do you all put much merit behind the car fax pricing? You enter vin number etc. and it spits out value. Or.... is KBB still the standard?
twoboarders
Here is the build sheet from my service advisor this am.
Features
Equipment: Bright Pack NAS
electric Sun Roof
A.B.S + Traction Control
18" Front & Rear Vented & Dirtshields
battery isolation switch
H7 Battery
ATC Air Conditioning
Hevac Controls USA
Wheel Arch Liner
Remote ICE controls
Home Link
Voice Control
Integrated MOST 6 CD
Enhanced Nav Full Colour / Touch Screen
Hi ICE Branded
Nas Mapping DVD Disc
Audible Seat Belt Warning
Inertia Front seat Belts-ALR
Air Bag Sensor
Loadspace Nets (2)
Seat Belts - Standard NAS
Electronic Air Suspension
Integrated Vehicle Dyamics
Front Axle Open Diff
Rear Axle Open Diff
Tyres Goodyear
Alloy 8x18 Style 2 255/60 R18 AT
Front Rain Sensor - Windscreen Mounted
Fixed Rear Roof Light
Footwell Lighting
Glovebox Lamp
Loadspace Lamp
Dome & Map Lamps
Elec Htd Adj Door Mrrs
1 flat / 1 convex (US) mirror glass
Twin Sunvisors Vanity Mirrors Illuminate
Auto Dimming Rear View Mirror
Leather Steering Wheel
5 Seat Configuration
Heated Seats- Driver and Passenger's
Drv & Pass Electric front seat adj.
65/35 Seat Split
Facia Dimmer Illumination
MPH/KPH Speedometer - NAS
Heated Rear Windscreen
Heated Front Windscreen
Tail Door Wash Wipe
Heated Front Washer Jets (Windscreen)
4 Passenger Grab Handles
Electronic Park Brake
Frt/Rr Toughened with Privacy Glass
Power Assisted Steering
Manual Tilt & Reach Adj Steering Column
LESS Fuel Filler Flap - Central Locking
Number Plate Plinth - NAS
Badge - LR 3
Roof Rails
Scissor Jack
Front fog lamps
Puddle Lamps - Front and Rear
Automatic Headlamp Levelling
Headlamp Power Washers
Xenon Headlamps + LED Signature
Automatic Low Light Sensing Headlights
Rear Lamp - Side Marker
Manual Cruise Control
Manual Child Safety Latch
Cold Climate Pack
NAS Exhaust Muffler
Perimetric Protection
315 MHz/non UWB Door Lock Frequency
Bonnet Lock
Automatic 6 Speed w. Steptronic
Alpaca Tunnel Console
Message Centre
Cup Holders (2)
Cup Holders (2)
Cup Holders (2)
Cigar Lighter and Front Ashtray
OptiKool Glass
4 Door Estate
Unleaded Fuel
Leather covered gear knob
OBD II System
SE Trim Level Pack
Shift Interlock
4.4 V8 AJ Petrol
LHD
Trim Details
Trim Items: Leather Seats
Ebony Black Interior Environment
TPO Trim Finish
Alpaca Beige Carpet
Serial Numbers:
Description:
Engine number ELH00141204 B19435
Gearbox number 136932
Transfer Box A0031687
jwest
Seattle WA
Compare on autotrader and maybe cars dot com. That’s a good indicator too.
