oil change question
D
discoII
just purchased a 2000 land rover discovery II and want to do an oil change. what type of oil,and filter do i use?anything else i should change?
D
discomike
Hard to say what else should be changed with out knowing the mileage???
Same for the oil, where do you live??
Mike j.
D
discomike
For your area you can use 20/50 or 10/40. I use 20/50 Castrol blend and a 3001 K&N oil filter which is about the best you can use on a Rover.
Not knowing what has been done in the past I would say play it safe and do all the fluids. Remember Rover used synthetic from the factory and I would suggest you stay with it. (0 wt for the diffs and t/case, Dextron 3 for the transmission I use Vavolina's synthetic for the power steering and brakes. I to[ everything of with Lucas additives and have a happy truck.
Good luck with your truck,
Mike J.
D
discoII
Monty said:
Where? I'm not too far from Sac either. Welcome to LRW.
im actually in dixon, what about you? where are you servicing your discovery ?
Paul p
