Oil pick up tube
S
snodog
I'm dropping my oil pan to clean it out as well
as check screen and pick up tube. My question,
is there a gasket for the pick up tube?
T
testuser
It says "Refit oil pan using a new gasket" in the workshop manual.
S
snodog
Yeah,I also saw that but manual states "if the oil pick-up is removed,
a new gasket must be used when refitting" Not sure if they mean just
the oil pan gasket, or pick-up pipe gasket (if there is one) Oh well
guess only one way to find out.
H
hama
any idea if there is a pickup tube gasket or not? as im dropping my pan next weekend and want to get the correct gaskets before doing so, if you have the part numbers for the gaskets that would be helpful too, i got a v8 99 d2
HaMa
STQAddie91
