JerryT said:
I have this same problem, after a drive and i turn the truck off I do hear the electric fan going. Is this different the the fan with the fan clutch? How do you check to see if you have a bad or failing water pump? What is the best way to check if your radiator is clogged?
Thanks for your help.
I have a '98 Disco LSE, and I went through hell trying to get the overheating problem diagnosed correctly. In hot weather or if the motor is hot, your electric fans should come on, especially if you have the A/C running. The radiator in the truck is big enought to keep the Rover v8 resonably cool in moderate weather, even when clogged. But when you factor in outside temps. reaching near 100 and the load of the A/C, that motor is going to overheat.
The only way to check to see if or how clogged your radiator is, is to go to a GOOD radiator shop or a trusted mechanic that works on Rovers a lot. I went through a month of hell trying to figure out the overheating problem. Two mechanics, a radiator guy, a fan clutch, new radiator and $2000 later, my problem was fixed. I made the mistake of going to another mechanic that "has worked on rovers" to diagnose the orignal problem instead of my regular Rover mechanic. Bottom line was another mechanic installed a fan clutch wrong or used a crappy part. My mechanic was able to diagnose the radiator problem AND the clutch problem. He never charged me to fix the clutch problem.
Don't let the car keep overheating. The engine is aluminum, and eventually you will melt your heads...
