F
faisal_in_laurel
Hello everyone. I am new to this forum and in need of your help.
I have a 1995 DIscovery with 174000 miles. The vehicle has been running great until recently.
Yesterday on the highway the temp gauge went to the high (Ususally at around the middle all the time). I took my foot off the pedal and started coasting at around 1700 rpm and the temp started dropping. I took the next exit to a fuel station. let the car sit for a minute and opened the cap of the Coolant expansion tank. The liquid inside looked brownish green and had a strong smell of either gasoline or oil. I purchased some coolant and mixed it with water and poured it in. It seem to take about a gallon to bring it to the correct level.
Then I started on my way home and it was ok as long as I stayed within 2000 to 2500 rpm. Any higher I could hear some gurgling noise from in front of the dash.
What could it be? I should also mention that I usually drive this vehicle only during winter and it did sit for a while. I have put 250 miles since and the oil was changed.
Thanks for your help.
Faisal in Laurel, MD.
