Oxygen sensor wire colors
softekfl
1998 Land Rover Discovery
117000 miles
started running rough over 1500 RPM's
would correct itself after warming up
mechanic originally could not duplicate problem, had it for a week
finally it happened again, mechanic said it was the mass airflow sensor
replaced it
a day later the same problem appeared
I think it's the oxygen sensors
Ordered a universal one (a pair of them for the front)
problem: I can't match up the colors on the 4 wires
new sensor: two white cables (heater), black (signal), grey (ground)
my old sensor: black, red, yellow, white
any help would be appreciated
Sincerely,
Jessie
www.bocasolarhome.com
running rough over 1500 rpm's.... could be fuel filter or fuel pump... not to mention plugs or wires.
How about a maintenance history.
softekfl
sensors
The store had given me the wrong oxygen sensors.
They were the wrong size.
The new ones came in today and the 4 colors on the cables matched
the originals. But the electrical connectors were a little different.
I cut the cables and attached them to the original connectors.
After I replaced them the Disco started just fine, and my RPM went
smoothly over the 1500.
I test drove it around town and the highway and it all seems fine now.
Glad to hear it... but I would still wonder what caused the sensors to go bad... generally it is caused by the engine not running properly... I would still check the plugs, wires, air cleaner... even clean the MAF sensor....
softekfl
Just days before the problems, I had changed the spark plugs, the spark plug wires and the MAF, and the air cleaner was just replaced 3 weeks ago. THe mechanic originally had told me that the MAF was faulty, it could have been it.
tragic1
