P38 MAF problems
Brambs
Firstly can a say a big hello to you all.
I am wondering if any one can give me some advice, before the hubby sells the car or me!! I own a 1996 P38 which is a 4.0 SE with a LPG conversion, I've owned this for 8 months and have no probs at all untill a week ago.
Last week while running on gas it backfired once or twice a couple of days running then the following day it backfires 4 times one after the other, I flicked it back to petrol and it got me home where i discovered the backfires had blown the air hose off, I reconnected this tried to start the car and it would turn over but took ages to fire up on petrol and then it would just die on me unless i kept feathering the accelerator (thats when i had to ring the hubby and tell him i'd broke it!). After reading posts on here everything pointed to the MAF sensor so i disconnected it and the car started with no probs, went to breakers yard and got a secondhand replacement MAF and fitted it and still the car won't stay running, Maybe faulty MAF i thought so swapped it for another that was gaurenteed to be working but still same problem. When not connected to the MAF the car starts and runs great on both gas and petrol and it would appear that there is no fuel starvation or blockages.
I've looked through all these forum pages and everything is still pointing to a broken MAF. please does anyone have any ideas as to what else it could be, i've got no error codes/msg on my dash.
Many Thanks
Claire
When you say you bought one that was to be working was it new or used?
When you disconnected it, do you mean just the plug or you removed it completely?
Brambs
Hi there
Neither were brand new, one was second hand and the other was taken from a working RR just so we could test it. When i said about disconnecting i left it on and just unplugged it at the bottom.
Cheers
At this point I would recommend plugging in the one you bought, but you may need to reset the ECU for it to take effect.
Nico3dd
Venezuela
Hello, did you guys finnaly solve this issue? I'm having the exact same problem and the spark plugs keep on miss firing due to excess gas. Have to take them out an clean them every 500miles. Replaced the maf and still nothing. How to reset the ecu?
