95Classic
I have a 1995 RR Classic and it will not shift out of park, I have replaced the brake switch and a blown fuse, but the 15A fuse keeps blowing when I shift. Here is some background info:
-The brake lights will only illuminate if the key is in the forward position.
-When the fuse blows the brake lights do not work at all so they must be on the same circuit.
-After replacing the fuse and holding down the brakes while the key is in the on position, the fuse does not blow, the fuse only blows when I begin shifting into and out of park. after about 4 shifts the fuse blows.
-I have peeked under the dash, and in the center column to look for any arcing wires, but have not been able to find any yet.
-There is something that is causing the fuse to blow, but I do not know what.
Does anyone think that a faulty brake light switch might be causing the problem? I am talking about the switch that the vacuum hose connects to for cruise control.
If anyone has any ideas of what to do next please let me know!
Thanks
Thanks
