Power Seat-Back
El Conde
1997 Discovery SE7, 100,000 miles: I've had this vehicle for about three weeks when, all of a sudden, the seat-back on the driver's side would recline but not move forward! Jiggling the switch moved the back so far back that I was beginning to look like one of those "Blue Hairs" (at this point, I'll take hair of ANY color) that you only see the hands on the steering wheel but no head! I checked the switch with an ohm meter and it was O.K. Reading in the forums here pointed me to the two fuses under the seat, about which I was not aware - but they were still good. I jiggled (this is about as technical as I can get) the cables going to the seat from the back and, all of a sudden, the seat began to work! I adjusted it forward to a comfortable position and, hopefully, it will never be moved again! This probably won't help anybody but this forum was so helpful to me that I wanted to add to it. Of interest, the driver-side seat controls will work only if the driver's door is open. The passenger side controls will not work with just the driver's side door open.
Chongo
Open circuit
Hello EL CONDE, It sounds to me like a open circuit or ground problem,
Especially if you can perform a harness wiggle test and make the unit function. Start by checking all connectors and wire for continuity, I’m sure it will lead you to the problem.
Good luck, I hope this helps…………. Chongo :bandit:
El Conde
Thanks for your help, Chongo. I'll keep checking but I hate these problems that fix themselves for no reason at all - one never knows when it's going to crop up again. I appreciate your help.
Regards,
El Conde
