Power Windows
jet1970
OK. Need confirmation. Does the 'driver' side window have auto up? All my other windows have auto up and auto down. My 'driver' side window only has auto down.
Thanks,
Jeff
crewcabrob
Hi,
It has auto up too. Most of the time it just gets out of wack and needs to be reclaibrated. If you look in your owners manual it will tell you how to recalibrate it.
If that doesn't work, (like my current issue with the passanger side window) you get to take a trip to the dealer.
Rob
crewcabrob
Glad you got it fixed. I take it that you just needed to calibrate it?
Rob
crewcabrob
By the way; are you mountain biker? I saw your avitar picture and I wanted to assume that Jet was for Niner's Jet.
Rob
Count Laszlo
Just close all doors, turn on ignition, and which ever window doesn't work (auto up) rolled completely up, just hold the window button up for one second, you'll hear a faint "click" and then it's set and should work.
jet1970
That's exactly what I did and it is working now. Not sure why it stopped in the first place though...
jet1970
PanKyiv
