Question about a sensor
L
livefreeordie
I have an 89 rover , and I was wondering if anybody knew some common causes for the EFI warning light to come on
D
discomike
There are too many reasons, knowing Rover.
How is it running, has anything changed?
You are going to need to get it to a mechanic for an answer.
Mike J.
D
disco1
Have you run it low or out of gas? If not, check the oxygen sensor. If you disconnect the ECU, then reconnect it, the fault sometimes clears itself.
rwmathews
