Radio....help
R
ROD
Hi
Bought My Self A Second Hand L/r Radio Cassette To Go In My Disco. Fitted It Ok. But The Guy Who Sold It Me, Did'nt Tell Me How To Put The Code In. I Assumed It Had The Details In The Box ??
It Has No Display. And I'm Told To Use The Numbers.. But How. Also It May Be Locked? How Can I Tell And If So. Is There Anywhere I Can Go To Get It Unlocked.. Can Any One Help...
D
discomike
Does the dial light up, does it say it needs a code, have you checked the fuse?
The code is usually on a card in with the owners manual, it is a 4 digit number that you put in by pressing the radio station buttons.
If the dial doesn't light up you may have a bad fuse or a dead radio.
Good luck,
Mike J.
R
ROD
Thanks For Help.
No Manual With Radio. Just Code..
Radio Lights Up.ok So Power There.
Model Disco Is .... 1990. Tdi.
D
discomike
After you turn on the radio does the srean ask for the code, or say code?
If so have you tried to enter the code by pushing it in by using the channel buttons, 1 being on the left and moving up as you go to the right?
Mike J.
R
ROD
Hi Thanks For Help.
I Dont Have A Screen On The Radio So All It Does Is Light Up The On Switch, Stays On A Few Mins. I Try The Code. Pressing The Numbers The Amount For The Code. Button One, Say 5 Times For 5 In The Code.. No Luck It Just Turns Off.
Think I Give Up With It. Anyone Want To Buy A Gen L/r Radio Casstte...
Paul p
