Raising the Vehicle via GAP Tool
pabs406
Hi Guys. So I finally pulled the trigger on a GAP tool. I took some measurements from the ground to the bottom of the wheel well after I did a +47 lift. The fronts measured 34.75” and the rears 37” in off-road mode.
This was an increase of .75” in the front and 2” in the rear from off-road mode at the +0 lift.
Is there a way to gain more lift in the front? I’d love to get that extra clearance going through some of the off-shoots.
Is there a way to manipulate the tool? Or is the only way to install lift rods and tune with the tool?
You're going about it incorrectly. You have to check your calibration values (maybe it was live values, I don't remember) and see how much buffer you have against the max value, then raise each corner that amount.
