Range Rover oil leak
donone72
First Id like to say this site rocks. I've never had a reason to post until now but i read it often to soak in all the advice. OK I have an 05 Range Rover my problem is i noticed some oil leaking from around the top of the oil filter housing and it just started because there was no oil in the garage i checked the oil and i was three qts low. I added the correct amount cleaned the area so i could see where my problem and started the engine and it was leaking from around the top of the oil filter housing . Its not loose or cracked . Any help would be great ... Thank you Don PCB FLA
Welcome to the forum, sorry to hear about your issue... I would remove your oil filter and make sure you don't have 2 rubber seals installed.
Paul p
