raqnge rover sport 2.7 td6 problem
cosmicstavros
2007 year-message appears transmission fault limited gears available.starts and then turns off with reduced power.changed the fuel filter and battery had to be charged!any suggestions what could be wrong??help
land230
fault in trans
I work at a land rover dealer in the states we have a lot of range rover sports come in with this fault .we find there is a fault in the rear diff motor if it has a locking rear diff there is a servcie message about this to replace the diff motor and complet a down load to the rear diff ecu .hope this helps if not i would like to know .
cosmicstavros
Thanks mate!For some weird reason after unplugging the cables going into the injection system -was trying to check them ,put them back in and problem has dissapeared!Dont know whats going on.Can you help me explain how to do what u said in case it comes back on!usually was happening after 90-100 miles speed.
PE_in_UAE
