Reducing wheel size
speedmancool
Greetings Joey.
I was considering the meassures 265/75 R16 for my Discovery, but another user, basstard ,says they have to be 31 in diameter to work. What happens if they are 31.7? Can the tires become a problem in that diameter? In advance, I Thank you so much for your answer
basstard440
Thank you for your tip. What happens if the tires Im looking at are 31.7 in diameter? They are the Dunlop Mud Rovers.
I almost buught them, but Im now| waiting your response, since it seems you know about this issue. Thank you very much.
I think you will be OK with that size. with the 32's at full articulation I would get a little rub. Not bad just a little bit, That quarter inch probably would have bee enough and it probably would have self corrected. Good luck and happy wheelin, It'll be a different truck after you get them cleats on there. Something else to consider would be a "center differential lock". These are probably the 2 greatest bolt ons to a disco that will help you get into some trouble :biggrin: .
Discovery Series II
255/65-16: Stock tire size.
255/70-16: Just a bit taller than stock.
265/75-16: Taller and wider than stock, possible to fit without lift. minor rubbing. Looks real balanced with mild OME lift.
285/75-16: even taller than 265/75-16, r requires a bit more lift than the regular OME lift. some have fitted OME751 from Discovery series I, and changed SLS sensor in the rear to achieve almost 3 inches. Gearing and shaft strenght become issues.
255/85-16: a bit taller than 285/75-15 but narrower. Gearing and shaft strenght become issues.
speedmancool
Basstard 440, thank you so much for the information. It was very helpful. I will keep all those facts in mind.
wolf
Thank you for your tip. I visited the Atlantic British web site and I found the wheels I needed.
also,if you talk to Eric Riston there @ AB, he will make you aware of any shipping deals etc (i.e., you lucky folks south of the border get free shipping more often than not - especialy on orders over $200.00)
speedmancool
Joey. Once again, me. I just put the 265/75 R16 on the 04 disco and guess what? they didnt fit. When I turn the wheel, the front bumper gets in the tire´s way, so I dont know what to do. What is your advice? Should I lift the truck? How much? What is an OME Lift? Thank you very much, Im a little stressed, since I wasnt planning on any lifting, but I think I dont have other choice.
Sid1577
