Remove Driver Door handle
marting
Hi all, 2012 LR4 HSE, needed some advice on how to replace the front left (drivers) door handle. It looks as though it should pull out or snap out but the door lock where the key goes I think needs to be removed. Anyone help with how to replace this easily and do I need to remove the door lock where the emergency keys goes first.
Help much appreciated. Thanks
BBLR3
St Petersburg, FL
Good video here on all things door related:
The lock cylinder does need to come out to remove the handle assembly. It is held in with a small torx behind this black gasket. You just need to loosen it enough for the lock cylinder to come out. You do not need to remove the screw completely.
