Replacing engine
gwhite
I have a '99 Disco II that i think is going to need a new engine.Have coolant mixing with the oil, possibly cracked head or block? Does anyone know good sources for used/reman engines? Also what does secondary air refer to?
gwhite
Mike, I live in Western Maryland about 2 hours south of Pittsburgh,PA.
chris02disco
Could be blown headgasket. You might want to do a search and read up b4 replacing engine. My 02 cents.
gwhite
Thanks Chris, Did have my mechanic test and the head gasket is bad. Didn't know if this would let coolant mix with the oil.
You won't know for sure if it is just head gaskets or if you dropped a sleeve. Have someone pull the heads then decide what to do.
If you need an engine, get back to me and I'll get you a couple names to call.
rainandsun
where you at dude? there's a lot of Maryland good auto repair shops that you can look on automd.they also gonna help to estimate the cost for you to know in advance.
Paul p
