Ride Height Sensor
AxelR
Hey all,
So I just got my first 2 suspension faults.
I checked what it was with the IIDTool and here's what came up:
VIN: SALAK2D47AA536xxx
Vehicule scanned on 07-02-2014 18:40
Using IIDTool+BLE
ABS-Brake Module
U0421-68 (2B) Invalid data received from ride level control module - Algorithm based failure - event information
U3003-62 (28) Battery voltage - Algorithm based failure - signal compare failure
RLM-Suspension
C1A06-1C (AF) Rear right height sensor - General electrical failure - circuit voltage out of range
I cleared the fault the first time and been driving around without problems. But it happened again today (so twice within 24hrs).
I did my best to check the sensor and all seems fine.
Any idea of what this might be?
Thank you
Sent from my i&iPhone
suvowner
you probably have a wire somewhere making contact with ground and causing the voltage changes......
AxelR
Thank you.
I will look further into it and I'll give a call to the dealer if it happens again.
I'm also thinking that I might have a bushing problem on the front passenger side. I need to check that too (parked on the street with snow everywhere isn't the ideal situation for getting under the truck). I hear a light sound when I drive slow over bumps. Noticed it for the first time when I went off-roading two weeks ago.
MArsel
