RRS HSE 06 break pad wear sensor
aeljr52
Can anyone tell me where the connection is from the front brake pad wear sensor ? No problem with the connection coming from the pad, but I loose the wire where it goes up in the wheel well. Its just a molex connector but can't find where it connects to. Maybe under the dash on the inside of the vehicle. 2006 Range Rover Sport HSE non-supercharged.
socalrovershop
just take a couple of the clips to the wheel well off its right under there being held by a clip. pull it down into view and you can disconnect it.
PE_in_UAE
