Running lights?
lowwill
Hey guys my 98 disco le 95650 miles left rear running light dont work but the brake light does? What you think
Eekie
Bad bulb, bad ground, corroded terminal, loose wire....take yer pick. The only way to diagnos the problem is to pull the lens and check er' out. Sorry for the short answer but there are alot of reasons for non working lights.
lowwill
hey every bit counts I also heard that the bulb has too parts to it.
DirtyDisco
A while ago I was wondering what those lights did; they never seemed to light up. I finally realized there's a button on the dash that turns them on. I found one was out and I replaced it with a new bulb and it worked fine. So maybe it's just a bad bulb or something wrong with the wiring itself.
