Spare tire question
samterri
Norfolk, VA
Hi everyone,
I looked around the forum for this question, but didn't find an answer. I recently bought an 06 LR3 SE, which came with new tires, but the spare has a leak. The size tire I'm running are the usual 255/60/18's. I found a used Michelin tire that's a 255/55/18. Will that work for my spare, or should I find the correct size. The tire's $50. Let me know what you think. Thanks!
Sam
Team Jeff
Supporting Member
Supporting Member
The concern is the diameter, if it were me I'd find the correct size.
CMGRover
As long as it is the same overall diameter (and not a Michelin) (most use a 185/something/19 spare), it should be fine. :biggrin:
e24kgold
the stock size from the factory on the SE is 255/55-18
255/60R18 for the SE. 255/55R19 for the HSE.
