Starting issues
Shredahead
Every once in a while my 2011 LR4 will have this issue when starting. Anyone else have this and any knowledge would be appreciated. So I pushed the start button the starter cranks but the car does not start. After a couple seconds I hit the start button again to stop the starter. Then press again and it starts up fine. my mechanic found not fault codes last time it was in. Only does it ever once in a while and can't identify any reason for this. Never has it done this twice in a row. Always starts up normally the second try. Anyone???
PaulLR3
Boston
I'd have to guess the fuel pump is on the way out if it cranks but does not start.
Shredahead
I had the fuel pump replaced less than 5000 miles ago. Unless this new one is going bad?
PaulLR3
Boston
We had a starting issue with one of our LR4's...it would not start unless you pushed really ******* the brake pedal. The brakes were pretty worn and new brakes returned the LR4 to starting with light brake pedal pressure.
