starting problems RR TD6
muffster
Hi fellas.
Ive got a 2002 RR TD6 which usually doesnt miss a beat but it wont start! It turns over as normal and starts up only with power start squirted into the air intake, however when i turn the ignition back of, then back on again it wont start. I think its some sort of priming issue but cant help thinking its going to be expensive!
Any help on this would be appriciated.
Many thanks.
Muffster.
Sounds like either an injector issue, or a fuel pump.
DO NOT continue to use Power Start to start you RR or it will eventually cost you more than you want to spend.
muffster
Ok mate thanks for that. Any further ideas on an issue with the injectors?
Thanks.
Muffster.
Depending on mileage, I would look at changing fuel filter, air filter, have the injectors cleaned. and never hurts to have the fuel system pressure tested.
muffster
Great.
Where is the fliter. And are the fuel pumps easy to change?
Thanks for the info.
Muffster.
Paul p
