Steering noise
ar_ken
Hey all,
My truck currently has about 130k KM (81k miles) on it. When I turn my steering wheel at low speeds, I can hear a faint mid-to-high pitch noise. Anyone has this experience? I'm hoping it's only a steering shaft that needs some lubrication...
Thanks for any insight!
When was the last time you did a p/s flush, when did you last replace your belt?
ar_ken
Mike: I haven't got a P/S flush done since I got the truck, sounds like it might be a good time to do it...
As for the belt, what belt are you referring to?
Another quick question, I take my truck to my buddy (who's a mechanic)'s shop, he uses a 4 point hoist... what suspension setting do you use when the truck is hoisted?
Thanks a lot!
socalrovershop
land rover has an additive that must be put into the system . makes the seals swell to make that noise go away. its a tsb
Rover does not recommend an additive anywhere in its manuals for power steering. I do add a 1/2 bottle or more of Lucas P/S Stop Leak to a full flush to help keep the valves freed up.
As for the hoist, any mechanic will know how to lift a truck with a full frame.
ar_ken
Sorry for bumping an old thread, just want to give an update to my steering situation.
The dealer told me that there is a slow leak in my P/S system. However she did say that the leak is very slow at the moment and I can just top up the fluids once a while and keep an eye on it. Apparently the solution is a new steering shaft which is a 1,100 dollar job (CDN dollars).
Sorry if I didn't make it clear about putting it on a hoist, I was more wondering about the impact it would have on the air suspenion system? What mode should I put it on before hoisting it up? Or should I just leave it alone?
Thank you very much for the help so far.
