Steering Wheel
Disco0311
Hi:
I have been following your forums for a long time now. Maybe one of you can help me.
Problem: I replaced my horn switches and the wiper switch - I had to pull the steering wheel out - replaced the parts - now I cant place back the steering wheel back into posittion - It slides easily a little, but stops half way - this is causing a craking noise in the steering wheel when you turn it - Do I need a special tool ..... please I live far away from the mecanic, so I want to try to solve this.
thanks
Luis (2003 Discovery II, 60000 miles)
It looks like any other steering wheel install, just line up the pin Slide it into place and use a new locking nut. Tighten to 32 ft lbs of torque.
Disco0311
I think that maybe the problem is that I'm not using a new self locking nut. WHAT DO YOU THINK?
I will buy a new one and use a torque wrench. Which I will should I buy, should I buy a normal one or a dial type torque meter. I ratter buy one that I will always use in my Disco.
Luis
I prefer the dial type, they seem to be very accurate.
BCNJ
