So after having the same problems with water leaking into the cabin intermittently, I snipped the drainage tubes, but yet still had the leak.
So I removed the passenger side A-pillar and found the problem. The tube is bent where it turns to go down the A-pillar. The bend is clearly severe enough to restrict flow down the tube. Like when you bend a garden hose in your hand to stop the water flowing.
Any ideas on how to fix this other then replacing the entire tube? The plastic is tougher then i thought it would be, so you can't exactly bend it back into shape.
Thanks
Thanks
