Fawwaz Baksh
I left my sunroof opened and after a heavy shower the inside got wet.
I'm now getting a HDC Fault a few minutes after starting the vehicle and when i change gears I get a transmission fault. Also, I can raise the vehicle, but not lower it. After speeding up, the vehicle will lower itself.
I took apart the center console vacuumed the water and left it to dry for the day, but it hasn't helped. Everything seems to be working (terrain select, Hi/Low range). I can change gears. Only issue is the errors and the inability to lower the vehicle.
I read online I need to change the control switch assembly to fix the issue with suspension, but I'm not sure what's causing the other issues. Grateful for any help.
2008 LR3 4.4L
75K miles
2008 LR3 4.4L
75K miles
