Surround cameras trubleshooting - Special Svc Msg
Posting this SSM for future reference as it shows location and detailed connections of the 5 surround cameras to the Image Processing Control Module (located under the driver's seat) for DIY troubleshooting of malfunctioning cameras with a diagnostics tool. This only applies to owners with Vision Assist, of course.
Reference SSM72248
Models LR4 / L319
Range Rover / L405
Range Rover Sport / L494
Title Surround camera inoperative
Category Electrical
Last modified 05-May-2015 00:00:00
Symptom 205000 Electrical Accessories
LR4_Discovery 4 IPCN camera connections.pdf
Range Rover_Range Rover Sport IPCM Camera connections.pdf
Content
Issue: A customer may report that one or more of the surround cameras are inoperative.
Cause: Poor connection at the camera module.
Action: Before consideration is given to appropriate camera replacement, please carry out the following steps:
1. Connect Symptom Driven Diagnostics (SDD) to the vehicle and carry out a Diagnostic Trouble Code (DTC) read of the Image Processing Control Module (IPCM).
2. If any of the following DTCs are present continue to next step:
DTC – 18 ‘Circuit current below threshold’
DTC – 31 ‘Signal failure’
DTC – 49 ‘Internal failure’ are stored, continue to next step.
If none of the above DTCs are present continue with diagnosis using SDD and with reference to TOPIx.
3. Access the IPCM and disconnect and reconnect the appropriate camera electrical connection at the IPCM that is not functioning correctly. Please view the attachments for connector location as follows:
LR4/ Discovery 4 - IPCM located beneath Left Hand front Seat:
C3342 Grey Front Left Camera
C3346 Black Rear View Camera
C3344 Brown Left Mirror Camera
C3340 Green Front Right Camera
C3343 Blue Right Mirror Camera
Range Rover/ Range Rover Sport - IPCM located adjacent to Left Hand Rear Seat Squab:
C3MP22D Grey Front Left Camera
C3MP22G Black Rear View Camera
C3MP22F Brown Left Mirror Camera
C3MP22A Green Front Right Camera
C3MP22 Blue Right Mirror Camera
4. Clear the fault codes.
5. Check all camera images for correct functionality and carry out a further fault code read of the IPCM.
If any of the DTCs have returned continue with diagnostics as guided by SDD and with reference to TOPIx to resolve the concern.
If the DTCs have not returned and one of more of the cameras are not functioning correctly, continue with diagnosis as guided by SDD and with reference to TOPIx.
If the DTCs have not returned and all camera images are displayed correctly return the vehicle to the customer.
