susjpension tech question
BoulderGT3
I'm getting a periodic suspension warning alert that clears itself when the LRS is turned off and restarted. I took it to the dealer and there were no codes stored so they couldn't find anything.
The LR3 randomly will raise or lower an inch or so at stoplights and in general seem to sit about 1.5" lower on the pasenger side when it's at normal ride height. It almost seems like the neutral or zero level calibration for lack of better description is off and it's telling the system raise the drivers side a bit.
Any thoughts on how to "true" this up or what to ask the dealer to do?
X
xcursion
Get your suspension upgrades from LR. That should fix the suspension faults. As for the auto raising or lowering, its nornal. Welcome to LR's automatic air suspensions.
rrover
Mine will usually lower a little bit after I have shut it off and then reopen a door. It seems it lowers on all four corners. Is this normal.?
Troy
X
xcursion
The slight height adjustment is the self-leveling feature of the air suspension. Cant tell you when it will occur since its done by itself but the adjustments should only be the front or the back at one time (hence leveling itself) If you didn't lower the car with the Terrain Response switch then it should not lower on all 4 corners by itself while stationary. I would take it to the dealer.
BoulderGT3
What upgrades are there after a 6/06 build? I thought the SW was pretty stable after 12/05. Thanks
X
xcursion
Yours should be up to date. But my dealer told me that there have been newer versions of the upgrade since then. You might want to get the latest version and see if that will take care of it.
roverdawg
06/06 might have been borderline for getting the suspension fixes incorporated into your build. I got mine (as a recall to my early 2005 build) a little after that. B036 & B036 were the sw (& hardware) updates that finally solved my daily suspension faults. Good luck!
BoulderGT3
It was in the dealer this week. It looks like the SW is current. The air suspension is schizophrenic in cold <20degree weather. They had a bunch of them come in with the same problem during the cold snap. The fix per LR is new ride height sensors which are on order and should be here in two weeks. In the interim, the weather was warmer yesterday and no suspension alerts or warning indicators.
qwertmonkey
OMG I have the EXACT SAME PROBLEM. I am soo glad to hear its not just me.
