System Code Help!
bigalrover16
I Am Trying To Locate A System Code Information Website Location...... Any Ideas Guys? ............... The Code In Question Is 174 #2 I Want To Fix The Problem Myself. ok as for the information i have found the code information states CODE 174 ----- = "O2 SENSOR IS RUNNING LEAN ON B"...... THEI IS A 2001 DISCO II WITH 91,000 MILES AND MOST RECENT TUNEUP I YEAR AGO I use "89 Octane Gas"............. IT spounds to me like one or more of the O2 sensors are not operationing correctly and my need to be replace! ............. i know that the DISCO II has a forward and and rear one.
Thanks For Any Direction And Help You Can Give Me.
Big "al"
Give us more information, year, mileage, when it was last tuned and octane gas you use.
A 174 code indicated that the passenger bank is running lean.
On other forums I am on, we have stayed away from posting fault code lists because, especially when you have multiple codes, the average person can not determine what the real problem is.
In the case of his 174, with the information given, he probably won't understand or know how to detect and fix it.
I believe if a person can get his codes read and posted back to a site/forum he at least stands a pretty good chance of getting it resolved.
Completely agree with you on the more info Mike, but figure the person asked for specific info... that is what I offered. If he does respond with more info I am sure we can help determine what is causing the issue and point to a resolution.
Well based on your attitude with your last post, I have annoyed you, and that is fine, I try to help people and for the most part, they don't have a clue where to start.
So, first of all, quit using the 89 octane gas, like every sticker on your truck tells you, 91 or higher. Second, if you know how, check for a vacuum leak from the air filter box back and all over the intake manifold, also check the air filter, are you using paper ot an oil soaked filter like a K&N?
Joey,
I wasn't critizing you, just making a statement about people who are given too much information, get that blank look on their faces and become dangerous when it comes to fixing something they know nothing about.
bigalrover16
thanks big mike!
HEY MIKE THANKS FOR YOUR HELP WITH THE INFORMATION I PROVIDED YOU I WILL CHECK THINGS OUT AND SEE WHAT TURNS UP!...... i am pretty good with mechanic's ... i have owned 5 rovers over the years .... several Porsche's..... and now BMW's and have done just about all of the mechanic work myself from motor Rebuilds... to tranny Rebuilds....... so i hope with your info i can solve the problems.
Thanks again.
Big "AL"
Mavsdad
