THINGS I CAN EXPECT TO CHANGE 75k-100K miles??
LRB
I have a 2005 lr3 v8 and am wondering if anyone can tell me common things that go wrong with the Lr3 after 75k miles. I know about the air compressor but what are some of the things that you are seeing go bad across the board? Thanks
JackMac
Diffs - I am changing the diif oil earlier than the recommended interval to help prevent premature wear/failure.
Also, ride height sensors have been reported.
Air compressor and bushings appear to be the most common, as listed above.
franklin
To mirror above-diff fluid, bushings-maybe a ball joint or two-
