touch sensitive turn signals
Ruper
Chesapeake, VA
So our 2013 Jep Cherokee has touch sensitive turm signals. you touch them in the direction you wanat to signal and they blink 3 times then turn off. Real nice when changing lanes. I am sure newer LR's have these however my 2005 LR3 does not. I'd like to have them as I get used to the Jeep's when using that then when I am back in the Rover I miss them.
Anyone heard of an upgrade like this. Possibly changing in some newer turn signal switch that works with a 2005?
What;s the fist year these were available in a rover and can these be swapped in?
douglastic
My 2007 LR3 has them.
I believe that feature can be activated in your 2005 with a Gap IIDtool.
catman
This does show up under the 2005 configuration files for the Gap Diagnostics IIDTool. Technically you can just turn them on, no part swapping needed. They were first standard in the US spec LR3 in 2007, but probably were part of the LR3 global software since launched in 2004.
Body Control Yes
Configuration Supported
3 flash turn signals • Disabled
• Enabled
