P0232-24 (28) Fuel pump A - secondary circuit high - General signal failure - signal stays high
Longtrail
Ann Arbor
Shiny battery and shiny chains!?
You’re living the high life;-)
Glad its sorted. Lesson learned, don’t underestimate the importance of a sound battery with all systems, even if the engine is running.
Indeed, lesson learned (and luckily without too much pain in this case!). Also, shiny new cooling pipes, crossovers and new starter motor (along with oil and coolant)! Next up is alignment as I know it's way off (on the front) and tires... I will start searching alignment shortly as I know it needs to be done correctly.
