Trailer Lights
S
sjskarts
I have a '94 disco, and I'm looking for the traile light hook up. Am i wrong to assume that it is pre wired? When I turn the signal on the little trailer illumination on the dash comes on. Is it possible that the hook up is there and i don't know where to find it??? I know the receiver come from the factory so hoping it is wired from the factory also. Any help would be great Thanks!
Kestreljr
I found mine in the back cargo compartment on the passenger side, where the access is to the break lights. pop out the little cargo holds then unsrcew the 2 screws and there it is. It was all pre-wired. (97 Disco)
S
sjskarts
Thanks im going to go look right now have to tow a utility trailer this weekend @ night so this will be very helpful!!!
S
sjskarts
Joey, quick question, do you know the color code for uhaul?as they relate to a standard flat 4? I know white is the ground, yellow is the left turn / brake, green is right brake/ turn and brown is tail light, but the uhaul colors are different
Thanks for any help !!
Normally they are all stardard. If you wire the adapter plug up to the disco correctly it will work.
Tumbler
