Troubleshooting coolant vacuum fill failure
Rendak
Atlanta
Alright, so the air compressor is not the problem. It really is a vacuum leak in the system. I removed the expansion tank from the vehicle, put vacuum plugs in the outlets, and ran the vacuum on the expansion tank and it held -24ish inHg, so I’ve ruled that out as the cause. I also hooked it back up and ran the vacuum again on the system and went around spraying all the visible and even somewhat hard to reach junctions with soapy water and saw no bubbles forming. The big radiator hose that connects to the top half of the front crossover sucks inwards under vacuum, as does the lower radiator hose that goes to the thermostat, and the hose from the transmission cooler to the radiator that serves as the primary port for draining coolant. Next up is the hose that goes under the supercharger and connects to the rear heater manifold.
I’m really hoping it’s that one, because I’m not excited about taking the whole damn thing apart again just to re-check the seating on the lower half of the front crossover or the junction between the rear heater manifold and the engine block.
Rendak
Atlanta
Side note, but has anybody ever used a mechanic’s stethoscope to find vacuum leaks by sound in hard to reach places? I tried it today to get at the junction between the lower front crossover and the engine block and didn’t seem to hear any appreciable difference between what that junction sounded like and what another junction that I knew wasn’t leaking sounded like.
Rendak
Atlanta
Well I took the whole damn thing apart this weekend. Checked the water pump (both O rings installed correctly), reseated the lower half of the front crossover pipe, and made sure the rear heater manifold was sitting right on the engine block and that the O rings weren’t pinched. Put it all back together and alas, the vacuum leak is still there! So gonna refill with coolant and pressure test. I just can’t imagine where the leak is. I’m worried about it being the head gaskets but haven’t seen any of the common symptoms associated with those kind of leaks.
powershift
Nevada
The way is to pressure test it and look for leaks. If you used the Land Rover brand coolant then get a black light and it will reflect like blood on Forensic Files. I don't think any other manufacturer does that lol.
Rendak
Atlanta
So I did the pressure test like y’all recommended and it turns out that the top half of the OEM front crossover pipe I got has a defective O ring! So I’m gonna return it and get another and hopefully that concludes my wild goose chase. Fingers crossed.
Rendak
Atlanta
I am so sick of this car. I finally got the leak fixed and was able to confirm that the system could hold a vacuum, then I vacuum filled the coolant, and then confirmed that the system could hold pressure too. Then I turned on the car, turned the heat to max, idled until I felt heat, turned off the heat, revved the engine at 2000 rpm for 8 minutes, let it cool completely overnight, and then checked to make sure the coolant volume was fine. Then I took it on a drive with the GAP tool plugged in and watched the temps and watched for low coolant warning. Everything was perfect. Drove it for about 30 minutes. Fast forward to this afternoon and I’m out on the highway and all of a sudden I get a low coolant warning and the car goes into limp mode. Pulled over and opened the hood and sure enough the reservoir is empty. But here’s the kicker. I go to put in coolant and it all leaks out. Got towed home and once I can get to my tools and take off the air plenum, I see that the lower radiator hose has come off.
I’m guessing that maybe the procedure that you do after vacuum filling didn’t end up causing the coolant to be sucked into the heater core like it should have, but that it happened on the second drive afterwards, but does that cause enough of a pressure or vacuum gradient to blow a hose off? Otherwise I’m completely clueless.
