Turn Signal Gremlin on '00 D2
Cal
The turnsignals and 4-way flashers on my '00 D2 are acting up!
Sometimes they work . . . most times they don't!
All bulbs are good; all fuses are good
What happens is this, I turn the signal on and the dash indicator light flashes once (maybe) then nothing!!!
Either side or 4-ways work (or NOT) the same way.
Could this be a flasher problem? Or maybe the turnsignal switch on the steering column?
I'm baffled!!!
Anyone ever have this Gremlin . . . and resolve it?????????
H E L P
Cal
If the 4 ways don't work either than not a switch issue but probably a bad flasher unit.
Cal
I found it ! ! !
The problem was in the right front turnsignal socket. The wiring harness plug socket had apparently self-destructed some time ago, and one of the leads backed out of what was left of the molded plug. It was intermittent for a while, and then just quit completely.
Of course the right front was the last socket I checked!!!
At any rate . . .problem solved!
Cal
w7412r
Sounds like the turn signal switch. Happened to me in 2006. I had to change it with the windshield washer switch for a total of $1200 at the dealer. DO NOT GO TO THEM!!! Get the RAVE manual, and order parts from Atlantic British, or someplace comparable online, then do it yourself.
