V8 Disco - Cruise Control?? - Help!!!
R
redarmytyke
Hi - Hope someone can help me with this one - I have a 99, V8i 300 series disco and lost the use of the cruise control and can see a small pipe approx 10 inches long coming from a part below the left of the throttle linkage (back right of plenum).
The problem is the other end has obviously come off from somewhere and as it's a bit tight at the back of there I just can't tell where. Being only 10 inch long it cant be far away but just cant work it out?
I assume it's something to do with the cruise but cant be 100% sure - If anyone has any ideas where it connect to it would be appreciated.
Thanks - Andy
Moose
There is a plastic T-connector for that vacuum line. The other lines run toward the front driver's side (NAS) headlight area, and back to the firewall. Mine usually falls somewhere near the master cylinder...
R
redarmytyke
Thanks very much I'll try and dig it out - its had a gas conversion so I've got that lot to fight through to find it also!!!
Thanks again
MrRodgers
