vibration
dragan
Do anybody now if car sits for 3 to 5 hours can tire got fleet spot.
I filing vibration on my steering wheel between 50 to 75 MPH for short period (5 to 10 miles)
I did road force balance in April. Do anybody know what can coos vibration
cdodkin
Flat spot is possible - but it would go away when the tire gets up to normal temperature.
More likely you have low pressure in one or more tires - easy to check and fix
Or you have some tire wear since the last balancing - and this needs to be done again.
I'd check the pressures first - do it with cold tires, not warm tires.
dry_fly
sounds to me like the truck has thrown a wheel weight. this happens from time to time when using static wheel weights. I would take it into your tire dealer for investigation. depending on how much you drive your tuck but usually between april and august I would be due for a rotation and balance.
dragan
Thanks for replay
After I did balance in April I vent beck to lr and tell what is the problem .
Lr dealer did front tire balance again. I still have vibration.
Why vibration disappear after 5 miles I don’t understand if my balance is of vibration should be there old-time
