Waist seal / door channel removal?
kilkenny
Is there a way to remove the inner waist seal on the driver and passenger door by itself? This is the piece on the front doors that is actually pressed up against the glass. Not sure how it comes out or if the door panel needs to be removed first. Thanks.
kwlr3
It's part of the door panel. Not sure if it can be separated once the panel has been removed.
