wheel alignment done now steering wheel crooked
jjvd21
I just had mine aligned on Friday by the dealer and the steering wheel is now slightly crooked / turned at an angle while going straight. Does anyone know if there's a way to loosen a nut or bolt so I can turn the steering wheel straight again and then re-tighten? Anyone have any ideas? Thanks!
Bluebird
Take it back they need to align the wheel and then lock it down. Very annoying isn't it.
gtc
If the LR3 is like most other vehicles, you need to remove the airbag first, then loosen, realign and tighten the steering wheel. It's actually a relatively easy process if you know how to remove the airbag cover, and can move the airbag without messing with the wiring; if you remove/damage the wiring you risk setting off a code for the SRS/Airbag system - guess how I know! (Not on an LR3, but on a BMW).
I'd probably try to get the dealer to do it - let them assume the risk (and they should have done so anyway).
